  #16
Old Nov 6th, 09, 04:39 PM
Lexlas's Avatar
Lexlas Lexlas is offline
Lex
Default Re: did I get ripped off?
Well at least you don't need a whole new engine like i had too. Getting ripped is part of life, i think. Lol ..
http://www.flickr.com/photos/10729028@N03/
68 Camaro / 400 ci / 3.73 10 / Edelbrock 650 4bbl
94 GMC Suburban / 350 V8 / K1500 4x4
98 GMC Suburban / 454 V8 / K2500 4x4
Old Nov 7th, 09, 05:55 AM
big gear head big gear head is offline
Freddie
Probably the one on top, but I can't be sure. Put them down flat and take a picture of the side where the thrust washer goes. The thrust washer for the posi gear is smooth with no lip. The thrust washer for the standard gear has a lip around the inner edge and probably won't fit in the posi gear.
Moser Engineering Dealer
'69 RS/SS396 pro street/427/4spd/9"
http://www.camaros.net/showroom/show...00&ppuser=1922
Old Nov 7th, 09, 09:44 AM
balljoint balljoint is offline
Oh oh, all my thrust washers have lips on them. I put it together using the ones in the top photo. Got .006 and .005 backlash by adding shims to the clutch packs. The spider gears were a little hard to put in, but not bad though. I took a photo anyway.
Old Nov 7th, 09, 10:43 AM
Freddie
Sorry, I forgot that you were working on the 8.5. I thought it was a 12 bolt. Looks like you got it right.
Old Nov 7th, 09, 10:46 AM
mrmuncie's Avatar
mrmuncie mrmuncie is offline
Lee
The smaller ones are for a posi.
69 SS 350 Camaro Muncie 4 Speed car.
I specialize in rebuilding Muncie's
Lee (In Louisville, Ky)
Old Nov 7th, 09, 11:58 AM
Since I dont have a service manual. What are the torque figures to see if the clutches are grabbing properly. I place the axles in each side right? and turn one wheel hub right? I appreciate the help
Old Nov 7th, 09, 12:02 PM
Freddie
Probably anything over 40 foot pounds is good. I set them up different when I put them together. I shim them tight. Did you use the limited slip oil additive on the clutches when you put it together? Lubrication will have an affect on the torque.
Old Nov 7th, 09, 12:09 PM
yes, the clutches soaked in oil and additive for couple days. Thanks again
