Performance Our High Performance area
Old Nov 3rd, 09, 02:34 PM
ClassicRiderHP ClassicRiderHP is offline
Default moisture in valve cover 454
i have a 67 camaro with a 454 that i recently rebuilt, after running the motor, not driving, just running. i pulled the valve cover breather and found white foam moisture, i thought it was just from the first start up, so i cleaned it and put it back on, the next day i found it again. the motor is not missing, is it possible i have a blown intake gasket?
Old Nov 3rd, 09, 02:49 PM
prostreet69camaro's Avatar
prostreet69camaro prostreet69camaro is online now
Default Re: moisture in valve cover 454
Did you put any sealant on the head bolt threads. They are in the water jackets and you could be getting the water/moisture from there. I recommend removing the bolts one at a time and add liquid teflon to the threads and retorque them. You can get it from the auto parts store.
Then clean the valve covers and try it again.
69 Camaro Prostreet - purple w/ghost flames , 502 w/ 871 blower
http://s268.photobucket.com/albums/j...treet69camaro/
Old Nov 3rd, 09, 02:53 PM
PowerWindows PowerWindows is offline
Jim
It could also be a rocker arm stud needing sealant as some (all?) of them hit water also.
67 Camaro: 454/TH400/4.10 12 bolt. Lots of options: PS/PDB/PW, tilt, tach, gauges and more. K-K + 797Z.....
Old Nov 3rd, 09, 03:25 PM
Skeeter55's Avatar
Skeeter55 Skeeter55 is offline
Skip
It could also be from not running a PCV POSITIVE CRANK VENTALATION...
1969 SS 498 BBC 636hp@654tq 4 Speed 12 Bolt posi-373 (The Orange Crush)..http://i145.photobucket.com/albums/r...5/Image002.jpg
Old Nov 3rd, 09, 03:43 PM
68rs406 68rs406 is offline
Sean
How much are we talking about? If it's just some scum on the valve covers or a spot here or there it could just be condensation, is it in a heated garage or in the cold?
Not running the car to temp and then letting it sit you can get condensation in the valve covers.
Sean
1968 rs, 406 CI "mouse".
If it's not heads-up, it's not drag racing....
Old Nov 3rd, 09, 03:48 PM
67_camaro 67_camaro is offline
No PVC and or not getting the engine hot enough to burn off the moisture. This is one reason why short trips are hard on the engine compared to freeway miles.
Lee
230" Dragster - 2000 LS1, 02020003 Speed Density, PRC 2.5 Heads,
MS3 Cam 237/242 .603/.609, Vic Jr. intake, Holley 1000CFM TB,
PowerGlide, 5000 stall converter. 8.70@154 MPH
My Projects Homepage: http://www.horsepowerracing.com
Old Nov 3rd, 09, 07:58 PM
i called my dads friend whose been a mechanic for almost 40 years, he said it was from moisture in the breather that couldnt escape, im going to try and spray both breathers with brakleen and get the water out, i do have an extra breather with a pvc valve so if the brakleen doesnt work then ill just put the pvc one in and see how that does
Old Nov 3rd, 09, 08:11 PM
Skeeter55's Avatar
Skip
x2 on the pcv...
Old Nov 3rd, 09, 08:47 PM
novaderrik novaderrik is offline
get that motor up to operating temp and keep it there for a while- the easiest and fastest way to do it is to go for a 20 minute drive.
you don't plan sincerity.
you have to make it up on the spot.
my 1974 Monte Carlo & 84 Turbo Buick
86 Monte SS that should probably be crushed
Old Nov 3rd, 09, 10:24 PM
Straight-line-69 Straight-line-69 is offline
Agree,..it's likely condensation from the blowby. Are you even running the engine long enough to pressurize the cooling system? If not, then coolant probably isn't seeping into the crankcase.
Run a PCV valve and bring her to operating temp. Make sure your themostat is a 180 degree or higher which will ensure your oil gets hot enough to vaporize the liquid water (212~ degrees). Once in vapor form, the water is removed by the PCV system.
So long condensation.
Old Nov 3rd, 09, 10:44 PM
larry A/SA larry A/SA is online now
Gold Member
What kind of heads?? Alum or steel?? Alum sweat big time. They look like mayo
Larry
Old Nov 4th, 09, 04:40 AM
Everett#2390's Avatar
Everett#2390 Everett#2390 is online now
Drive a '68!
Larry
X2, Alum moreso than cast iron/steel.
Give a man a rescue dog for the health of his soul.
My 68 Camaro http://www.flickr.com/photos/everettwn68
